Can a Pan cake compressor run a HVLP gun? Does the size of the gun make any difference? Try Porter Cables 6 gallon.
Yes, a pancake can run an HVLP gun but not for long. The guns use large volumes of air and a small tank will be emptied in a few minutes/seconds. There are differences between guns. Most of the pro paint shops I know are using Sata RP guns.
There are differences in technique as well. Spraying with minimal air pressure seems to be a counter-intuitive thing and most inexperienced sprayers struggle with it... trying to use too much air, which would obviously deplete a small compresser that much faster.
Although I am very partial to my DeVilbiss GTI, I suspect that AccuSpray guns are among the most efficient (i.e., least air consumption) so-called "conversion" HVLP guns out there. I own one Sata RP that I got what I thought was a really good deal on and I really don't like it very much. But, I've used Sata HVLP guns that were a distinct pleasure to spray with. A buddy of mine bought an indentical Sata RP and ended up selling it and then bought a Sata HVLP that he likes much better.
Ah shoot! Here I thought you had come up with a new way of making pancakes.
Wait a minute...
Maybe if I put the batter in the...
Be back in a few...
ChuckN and I have nothing of value to add to this discussion.
Your gun will have a SCFM requirement listed. Just compare that with the SCFM rating on the compressor. It also depends if you are going to be spraying all day long or for 5 minutes at a time. Each compressor should have a "duty-cycle" that says how many minutes of each hour it is rated for.
I would say probably not. Unless you're spraying very small projects of parts a pancake size compressor won't be able to keep up. It's very frustrating to loose air ( atomization ) during a spray sweep. When talking about spraying and compressor size, bigger is better.
Paul
ps the low pressure in HVLP doesn't mean low volume
Edited 6/11/2007 3:43 pm ET by colebearanimals
