I am making door way panels for a rehab we are working on 2′ wide 9′ tall. I plan on using poplar rails and styles and MDF for the panels. I am great at making the panels. Does anyone have a step by step for making the rails & styles? I have the matching set of bits just having the right knowledge of how to measure and cut them.
HELP!
Tim K
Go check out master Marc and his episode on raised panel doors. He goes into the measuring aspects as well.
http://link.brightcove.com/services/link/bcpid1344664476/bclid1344621875/bctid1344578184
http://thewoodwhisperer.com/
Glen
I do not know what size and make you have for cutters but with my cutter set I have to make the rails 3/4" longer than the distance between the two stiles in order to allow for the tenon. If the distance across the stiles is 24" and the stiles are 3-1/2" wide then the rails will be 24-7=17", then make them 17-3/4" this will allow for the tenon and the stiles will have a 1/4" x 3/8" deep groove for the rails and panel. All rails and stiles will have this groove in them along with the profile on the good side. Hope this gives you a little insight as to your measurements. The stiles need to be the full length you want such as 9'. I always cut the rail tenons first and then do all the other parts.
Edited 12/18/2007 6:07 pm ET by mrbird90
I have http://www.rockler.com/product.cfm?Offerings_ID=2146&TabSelect=Details for the rail and stick and http://www.rockler.com/product.cfm?sku=10604&cs=1 for the panel.
Tim
The groove or dado is probably 3/8" deep, check the instruction sheet or make a sample cut. If 3/8" then the information I provided previously will apply. Good luck. My cutters are for a shaper as I do not use the router for making doors.
