Looking for help here. I’m not sure if this belong in the “joinery” or “tool for woodworking” page. I’m trying to make some panels for a project but I’ve not been able to get the edges of my boards (one and one-half inches thick) to match perfectly. There is always a hairline gap when I butt the edges together which tells me my edges must not be 90 degrees.
I have a 6″ Jet jointer (had it for 6 months) and I’ve adjusted the blades 3 times using a dial indicator. All the blades are within 0.0001 of each other and the out-feed table. The front and back of the out-feed table are within 0.0005 of each other and the center is about 0.002 below the front and back. The fence has been set with the 90 degree bracket used for the dial indicator so I’m sure fence is accurate.
When the edges are parallel to each other there is the hairline gap. If I try to shave a fraction off then only the front edge of the board is shaved giving me an even greater gap.
I am somewhere between a novice and intermediate and I’ve never run into this problem before. I’m beginning to think it is operator error by now. Just how does one feed wood into a jointer?
My other problem with this project is gluing the panels. Even though I do a dry run I still have great difficulty when the glue is applied. I’m using 3 to 4 pipe clamps across the panel alternating sides and 4 C clamps for compression boards across the panel. If only I had two more hands. If anyone could offer some advice on gluing panels this would be appreciated also.
Only on rare occasions, (not in over 20 years) have I used a jointer to make edge joints. I much prefer a hand plane for this, so Im not even close to an authority, on jointers. If you were to feed alternating faces through the jointer, then if the jointer were out of square, the resulting angles would complement each other, and the panel would be flat. I plane my glue edges with both boards in the vise face to face, this way I dont have to worry about getting them at perfect 90 degree angles. You do want a very small hollow in the joint (along the length), as this puts more pressure on the ends, where a joint is liable to open up. Achieving this slight hollow, on the jointer was, for me nearly impossible; more often than not I got just the opposite. I guess you could solve your clamping problem by gluing up pairs of boards, until you get the full panel made. This way you only have to deal with one joint at a time. Also, it is a good idea to put only a thin film of glue on the joint, because the glue acts like grease, and the boards just slide around as the clamping pressure is applied. I deal with this problem, by sprinkling a pinch of play sand into the glue, after it is applied to the joint (keep it in the center of the edge, so it wont dull the edges of your tools when you surface the panel). The sand keeps the pieces from sliding around. You dont need much sand at all, only a few grains will eliminate the movement.
*Bill, one more thing to check on your jointer is that the infeed and outfeed tables are parallel. If not perfect, there may be gibs that you can adjust, or use soda-can slices of aluminum as shims to get the tables perfectly parallel. When you feed stock through the jointer, once there's some wood on the outfeed side, put all the downward pressure on the outfeed table. Theoretically you shouldn't have to, but it seems to help get good edges. I still almost always clean the joint with a jointer plane.When glueing, it helps tremendously to use cauls, or boards across the width of the panel, sandwiching the boards. Use hardwood (1" x 1-1/2" or so) on top, preferably with a slight curve along its length. For the bottom make up some plywood or solid wood "T's", 4-6" high, to act as stands and to clamp the cauls against. Put glue on the edge of the boards, hand-fit them together on top of the "T's", clamp the cauls up tight, then, last, pull the joints tight with pipe clamps or K-body clamps. Don't overtighten, leave some glue in the joints, just pull the joint tight. Your panels will be flat, the joints flush, and the worry reduced. No need for biscuits. There was an article in FHB in the last year or two about glue up strategies, that probably had some more tips. Good luck,MM
*Bill,FWIW, a scarfed joint is stronger, easier, and the more "accepted" way of joining two ply wood panels, at least in boatbuilding. The typical ratio is around 11:1, but can vary.Dano
*Even if the edge is perfectly jointed, even a slight imbalance in clamping pressure can open the joint, so its important not to over-tighten. In fact, I often use a "rubbed joint" in which no clamps are used. To make a make a rubbed joint, join the boards as usual, finish with a very light pass using a jointer plane on both boards in the same pass -- clamp the boards face to face, carefully aligned, and do NOT hollow the center. Clamp one board vertically with the joint edge up, apple glue to both edges, then place the secong board on top. Slide the boards together a little along the length (the "rubbing" part). As you do so, you will feel the glue start to grab. Stop and carefully align then and leave it for 15-30 minutes. If you want to, after the delay, you can move them against the wall or such. I prop a few sticks along the wall to support the assemble in a near-vertical orientation.By the way, clamping the boards face-to-face and jointing both edges at the same time works well on the jointer too, and compensates for any fence misalingment.
*Jim, I also rub the boards together until they grab, it helps spread the glue. How do you keep the boards aligned with each other, though? MM
*For the last 5 or six years, I've answered every question about "what do you want for (birthday, christmas, etc)?" with "clamps. Any kind, any size!".So now I've got a large collection, mostly of "quick grip" bar clamps. The full size versions get used often for clamping multi-board panels for glue-up. I've also got several miniature quick grip clamps, and they are PERFECT for pinching the edges of boards together at the seam. You can't clamp them too tight. The plastic pads don't stick to the glue line. They hold each board aligned as the larger clamps pull the joints tight. After about 10 minutes, I pull all the miniature clamps off and wipe clean their pads and the glue smear beneath them on the panel seams. I assemble my glued panel vertically. Stand the first board on edge, apply glue to it and the mating edge of the next one. Stack the second board atop, and align with miniature clamps at the ends of the seam. Continue with sucessive boards. Often I'll clamp the stack vertically to the table. Of course, quick grip clamps are good only up to about 24". The longer ones flex too much, in my experience. BTW, I've never been able to clamp panels "too tight" with quick grip clamps. I have seen it done too many times with screw handled bar clamps and pipe clamps. Squeeze too tight, and you can starve the joint of glue. Too much of it gets forced out.Dave
*Mike:Sorry, it's been a while since I looked at this thread.Once the joint is rubbed and grabby, I just keep the assembly in the vise without disturbing it. If the assembly is carefully aligned carefully plumbed in the first place, once grabby it doesn't (or at least very seldom) move.
