Considering buying a vertical panel saw capable of handling baltic birch sheets (about 5’x5′) and 4’x8′ sheet goods.
I can spend no more than approximately $2000.
Precision cuts would be nice but I doubt I can get super accurate cuts in a vertical panel saw. Probably the saw would be used for cutting large sheets to approximate size with precision cuts to be done on the table saw.
Speed and safety are my concerns.
Your advice is welcome. Thanks.
JLBreckenridge
http://www.sawtrax.com and http://www.safetyspeed.com have units that will fit your budget & do both 5x5 & 4x8. Sawtrax will also sell you just the tracks & mounting hardware, so you can build your own frame and save some $.
