I’ve got a panel I need to take apart. What’s the easiest way to take apart the glued panels w/o damaging the joints?
Is the panel floating in rails and stiles in a grove? If that is so, most would recommend you use your router on the back side to rout out the grove...replace panel and use molding to hold in place...goodluck
