Loved the videos, but had a couple of questions about the finish: Sand to 180 grit Antique Cherry analine dye in distilled water ??? After sanding the raised grain to 220, he used a Minwax oil-based stain, but didn’t specify the flavor. ??? He then used a 1 pound cut of Seal Coat shellac, but didn’t specify amber, blonde, garnet, etc. Optional polyurethane coat Wax & 0000 steel wool Please advise, as I’m still looking for my A&C finish recipe. Thanks, Chris
There are lots of peresonal choices to be made in finishing Mission or Arts and Crafts furniture, depending on the wood used and the look desired. First a few comments on what you have given. First, the dye. I prefer powdered water soluble dye in distilled water, to liquid concentrate in water (ie. TransFast over TransTint) Sanding after the dye should be VERY light--just to knock down raised grain. I'd use 320 grit only, not sanding TO 220. Personally, before sanding I'd apply a wash coat of 1 lb. cut dewaxed shellac (Seal Coat comes in only one color, blond, and comes from the can at 2 lb. cut.) Then I would sand the raised grain with less chance of sanding through and the fibers stiffened by the shellac. Then I'd use a pigment only stain, (actually a glaze since it's over the sealed wood), not a Minwax stain, most of which include dye, to give the dark pores in oak. The wash coat will preserve a bit more of the base color between the pores, but won't do so entirely since a single 1 lb. cut coat of shellac won't seal completely. Then for top coats, I'd either continue with a few coats of shellac--your choice of color, or use a wiping varnish. Polyurethane isn't necessary on firniture. You don't want a thick glossy finish on A & C furniture. Stickley use lacquer at some times. Remember Stickley was made in a factory.
Here are two schedules for mission finish, both by Jeff Jewitt. The first is more recent and is currently on Jeff's Homestead Finishing web pages.
http://www.homesteadfinishingproducts.com/pdf/mission_oak_rev11-2009.pdf
The second schedule was originally published by Jeff on the old Badger Pond forum, retained as an archive in the Wood Central forum pages.
http://www.woodcentral.com/bparticles/missionoak.shtml
I suggest reading both before deciding on your own schedule. Your sample boards should guide you.
