I want to build an extension table for my tablesaw. I’m going to top it with white formica. The table is going to be 4×4 and removeable. Which material should I use under the formica?
My prime consideration would be that it stay dead flat, and I think you can't do better than MDF for that. The drawback is the weight - it's considerably more than plywood. But I'd go with MDF.
DR
The traditional substrate under plastic laminate is industrial particle board. Many lumber yards carry it or will order some sheets. Plywood is likely to curl, never tried MDF. I use melamine quite a bit. It's not as heavy duty as Formica but it's cheap and ready to use.
tcbaldmtn ,
I second Hammers suggestion of using Melamine . It is low cost and stable and makes a great table top and work surface .
dusty
Particle board with melamine is OK, but definitely more vulnerable to dents and chips than a formica topped surface.
DR
Hi ring ,
Agreed that Melamine is not as resilient as laminate , but for a removable extension table for the TS it should work just fine . Plywood when laminated on one side only can have the tendency to warp , unless it is restrained say in a frame or part of an assembly .
dusty
hey Dusty,
I started off by suggesting MDF, not ply. And whatever it is, it should get the underside done with a cheap laminate for equilibrium.
I think we've somewhat "overkilled" this topic. It's just a shop surface, not rocket science. If it doesn't look good after a year he can throw it out and do another.
regards,
DR
Use Melamine. I have arborite on mine and the router bit marks really pi$$ me off. I wouldn't feel nearly as bad if it was melamine which it will be next time.
Brian
it doesnt matter what you use (mdf, ply or pc) as long as you put good sturdy 2.x4 bracing under the top to avoid sagging; and on a 4x4 top, weight really is not much of a factor, although cutting a 4x8 sheet of mdf without an assistant is a real workout. good luck - DKA
I also use melamine for all my shop surfaces. Generally what ever I do to damage the melamine surface would also have damaged formica, such as accidently drilling or cutting through it.
