What is the preferred material to use to make a pattern?
Hi Groucho,
MDF is a great choice. Depending on the size of the template 1/4 in. thick (small templates) or 1/2 in. thick (large templates) works well. Alternatively, Baltic Birch plywood in either of those thicknesses will do fine.
The most important aspect to making a pattern or template is to ensure that the edge is flat and square so that your tool (whether its a router bearing or a guide on the bandsaw) rides consistently along the template edge.
Matt Berger
Fine Woodworking
Thanks Matt!
Now does anyone know where to find 1/4" and 1/2" MDF?????????
Live in central Massachussetts...
Home Depot and Lowes should carry MDF in various thicknesses, as will most lumber yards that sell sheet goods. Baltic Birch plywood is a little hard to find, but you'll know it when you see it because the plys are very well distinguished.
My nearest HD only caaries 3/4" MDF. I will call Lowe's though. I like MDF; because it certainly is stable and sand good.
I did my dinning room in raised panels using MDF; and it looks fantastic. No movement either; that's a real plus!!
Looking at pattern ideas, I came across Steve Latta using a pattern sheet of MDF to cut corner cabinet shelves on the table saw(FWW 155). I have met Steve at a Williamsburg seminar and he is just full of great ideas on efficiency and getting the most out of tools. Everything I've seen by Steve makes sense and works well when I have tried it. Oh, he's a great teacher as well. Check this edition/article out- well worth the time.
Certainly will check it out. Thanks,
If I can throw my two cents in:
Baltic or MDF are great is you are making a pattern totally by machine- But a lot of patterns involve various curves which are usually done by hand. When that is the case I use thin (maybe 1/2") pine or mahogany. The solid wood is easy to work with hand tools like a spokeshave, scraper or handplane. The mahogany is best if the pattern will be around for a while because it is stable and not as prone to warping as some other species are.
Bob Van Dyke
