I have a Stanley diningroom table with a pedestal base. Recently the base has become loose at a certain point as shown on the attached jpg. When the top is on, it can rock almost 2-3 inches. It seems that the joint has become loose just above the block to which the legs are attached. I contacted Stanley but they could not provide any insight into the construction of the base. I cannot determine how to take it apart as it seems that all the pieces are solid wood. I’m assuming that they were glued and dowelled during assembly or maybe there’s a centre screw/bolt. I would like to take it apart so that I can repair the problem. Any suggestions would be very welcome.
Bob
The only thing I can think of, considering that spot would possibly be an all thread running all the way thru the pedestal. When you open it up, can you see any bolt/nuts... how about undr the bottom??
how loose are the dowels
in the holes. glue itself will not take the slop out
ron
There is a bit of looseness in the main 2" dowel. Should this be absolutely tight? The smaller dowel I'm assuming is only for alignment and I can make this fit snugly since I've had to drill out the old one. The two pieces of the pedestal do not necessarily fit perfectly. It seems that an adhesive/filler was use when the pedestal was assembled. I've had to chip the adhesive off. Any suggestions as to what adhesive to use to reassemble the pedestal. Thanks, Bob
snug fit is usually the requirement
to keeping something firm. glue works best when there is a firm commitment. in the previous sense, the so called adhesive/ filler didn't sustain itself did it, or we wouldn't be having this conversation. most adhesives will work providing a sense of workmanship has occured
the hole is more than likely a little eggshape from the seasonal changes along with the dowel. so really what is required is a new dowel of the required dimension. the hole resized to it's original roundness so that everything fits right, providing someone hasn't enlarged the hole with the malicious use of a chisle digging out the old chunks of glue. I usually precisely check the sizing of my dowelling beforee use as there now seems to be a lot of variance in measure these days, esp with the influx from s.e. asia
ron
remember that you have a 36 or 42" table top being supported by one 1"(or whatever size) it is dowel, so a little slop there is magnfied at the table top
your better off
getting dowel to match the hole. you can buy 2" maple dowelling. I have all h/maple dowel in stk up to 2" in 4' lenghts, so it is available. there may be a w/w shop around that may have some or will turn an accurate dowel for you
ron
A large round tenon, your 2"
A large round tenon, your 2" dowel, is a common way to attach turnings to each other. The smaller dowel is to prevent the pedestal from rotating at that joint. You can use a gap filling glue rather than try to make new parts which may not fit or last any better. The large top on a small pedestal puts a lot of strain on that joint and others. I often mix very fine sawdust with epoxy for such repairs, if it's real sloppy, you can wrap the tenon with epoxy soaked paper. They make a special filler to use with epoxy but the sawdust has worked well for me. A thin bead of a polyurethane construction adhesive in a tube, like caulking, could be used where the flats come together. Give the epoxy and adhesive at least 24 hrs. to set before using the table.
furniture repair in
a tube. aren't we skilled !!!. just remember the next time someone has to repait it, throw it away.
ron
The point is, there won't be a need to repair it. We aren't talking a valuable antique here. It's a top heavy construction with people leaning on the table and the weak point on the column has shown itself, not that there may not be other issues in other places but that area shouldn't give any trouble again if fastened securely. Less secure fastening has already shown what it will do, fail. The adhesive will allow for some seasonal movement without breaking. A different approach may be prudent in other areas but I'd make that column solid. Of course, if you like fixing the same problem over and over, don't take my advice.
I bet that
epoxy is your answer for everything
Thanks to everyone for their sage advice. I am always amazed that people can be so helpful. I love these forums.
What I've done is the following:
- I've drilled and inserted a 3/4 inch threaded rod through the whole works and attached it at each end with a fender washer and self locking nut. I've created an appropriately sized hole at each end so that the bolts are flush with the wood pieces.
- I've reglued the centre tenon and put in a new guide dowel.
- I've put adhesive on the matching faces between the two sections
- Then I've tightened everything and will let it set for a few days before using it. Probably not necessary but I'm in no rush.
Right now everything feels solid. Hope it stays this way once the leverage of the table top is applied.
Thanks again, all. Bob
