What are your opinions on these? Are any of you using them? If so are there anydrawbacks other than cost?
Dale
Dale
I've been using static, rorary and inverter types with 3 phase machines for over 17 years. They work great but it all depends on the particular application. You can run a whole shop or just one machine. What would be your application? Sometimes it's much cheaper swapping the motor and sometimes it's not an option. With an inverter I can turn a step pulley speed change to infinitely variable speed with a dial. Also depends on if you plan to add more machines then you want a rotary. Too many variables to give an easy answer.
Rick
Rick
This would be for one machine only. A 7hp bandsaw I am told rotary is a better choice. What are you thoughts?
Dale
In that case I agree with the rotary. A static only starts the motor and drops out. That's why they only give 1/2 to 2/3's power. You are only using 2 0f the 3 legs. A static might even be ok as long as you well over powered. I set up a 2 hp stroke sander with a static and occassionally we would bog it down. A rotarty will give full power. You can make a rotary using a static and a slave motor. You don't even need the static in a sense. You could use a 1/4 hp motor to get the slave going then put power to the slave and disengage the 1/4 hp. I usually get phase-a-matic converters from Enco. Phase-a-matic has provided good technical suppport on my applications. I'm no electrician but I've been doing basic stuff long enough and I use support of my local motor shop, electricians and suppliers to make it all work. I would get a static and see if you can get a three phase motor for a slave. Actaully sometimes in the classified you might find a rotary cheap enough. An inverter will give variable speed but for that hp it's pretty pricey unless. I'd call phase-a-matic and talk to your local motor shop for their take. Some of these bandsaws are direct drive and to put a single phase motor on will cost far more than a phase converter. There's at least a dozen converter companies out there. Ronk, Kay etc.
Rick
Thanks Rick
Eventhough I just need it for one machine, it looks like it would be a good idea to consider future equipment. I was visiting the site for Kay industries and was thinking of new possibilities.
Dale
