Looking for a little advice guys. New kitchen table, red oak.
Planning to use a pickling stain, then topcoat with water-base
polyurethane. I was thinking about filling the pores before staining,
(not a big fan of oak’s pores)any suggestions?
waterbase filler w/ or w/o colorant? Have never tried to fill on oak, is it a bad idea to begin with? Any advice would be greatly appreciated.
I've used the following process with great success:
Depending on desired result, I apply acoat of clear dewaxed shellac. I then dilute cheap white latex paint with water and poly... 1 part paint, 2 parts water, 1/4 part poly. Apply with a rag & let sit for a couple of minutes. I then wipe off excess & let dry overnight. This does a pretty good job of filling in the grain, but but you could repeat if it wasn't what you wanted.
I then add a little bit of this mixture to the first (and sometimes second) coat of poly. I let that dry for a day or two, then finish with 2 more coats of poly, sanding lightly between coats. It works well, is relatively easy, & does a decent job of filling in the grainy portions with the pickled white.
Good Luck
Bob
