Hi!
Does any one know of a good method for dealing with pitch pockets? I’ve tried heating them until they stop leaking, scraping them with a pick and filling the opening with epoxy which works sometimes. I’ve also tried cutting them out and filling the void with wood or filler, which works all the time but is neither quick or pretty.Any hoo, what to do?
Glendo.
Speaking as one who used to go through 70,000 board feet of pine per week (one flatcar load), the only good answer is: Don't buy wood with pitch pockets.
You've already tried most of the feasible methods of dealing with them. Usually when drying lumber for boards rather than dimension lumber, the lumber is heated enough to "set" any pitch present, but it's still a defect to avoid.
Michael R
I was afraid that would be the case. They seem so innocuous until they start drooling on the first heat wave of summer. After a long winter I can hardly blame them. Not that we ever have one here. I guess I'll just continue to avoid them.
Glendo.
Glendo,
Have you tried sealing the pitch pockets with shellac?
I have limited experience with pine and its ubiquitous pitch pockets, but I've had no further trouble when I use shellac. An added bonus of shellac is that it reduces--or eliminates--pine's tendency for blotchy staining.
Alan
Thanks, I'll give it a try.
Glendo.
