Pivot Hinge for Antique reproduction
I am building a reproduction of an antique flip-top poker table. The existing table’s “pivot hinge” is nothing more than a steel rod embedded in both the tabletop and the curved arms attached to the base. Any suggestions? The closest thing I can find is a pivot hinge Rockler sells, but it has an external flange that I will not be able to use. Thanks for your help.
I'd probably consider copying the original hinge. Maybe put bushings in the holes made of teak or lignum vitae or cocobolo or something of that nature. Maybe black Delrin?
Thanks. I was leaning more toward a plastic bushing and had not considered lignum vitae or another wood. The original table is mahogany. I made the reproduction in white oak (to match the owners furniture). My fear is that if I just use a steel hinge pin, the iron will bleed into the oak grain as it oxidizes over time.
I don't have my Maloof book in front of me, but I think he used a brass rod for some of his hinges. That metal might have less of the problem you're anticipating.
John
Don't be afraid to try and make your own hardward. You would be surpised what you can do with a hacksaw, a few files and some basic flat stock and round bar. A propane torch may also come in handy if you have to do any bending. Good luck.
Thanks. I am going to do it myself with a couple of hinge pins, a hacksaw, and a few plastic (hopefully UHMW) bushings.
