I’m fairly new to woodworking and only do it as a hobby, but it has become very apparent to me that having a planar and jointer would greatly open up my possibilities when it comes to material. I don’t have a lot of money to spend, however I am willing to spend a little more if there is a significant jump in performance for a couple hundred dollars more. For example I had originally planned on spending $350-$400 dollars on a table saw, but decided to spend a little more once I heard all the good things about the Ridgid S3650.
This leads me to my two questions. First, would you recommend a combination planer/jointer or should I be looking at purchasing them separately? Second, can anyone recommend a moderately priced model of each?
Thanks in advance for any suggestions.
My advice is to definitely get a planer and skip the jointer for now.
I have used a Rigid 13" for years. Perfectly fine machine unless you are getting into seriously big stuff. I had the big Dewalt and couldn't get rid of it fast enough. That was one example of spending more and getting way less. New 16" Laguna just now showing up.
At the moment I do not have a jointer and have developed very effective methods to work without one. You can always start with hand planing and a lot of guys will tell you that's best. I don't hand plane yet but am getting ready to for certain things. Mostly, I jig everything. So I have a straight line sled for my table saw. And I have several very nice and well maintained straight edges for using with a router to make perfect edges. So my advice would be to spend your money on a really nice router set (Makita or Bosch combo) and use that for now. You'll have more flexibility with a router and will likely find that you get along very well without a jointer. Then, when you're tired of spending so much time on the set up for jointing (that's when you're really in deep and the wife is pressing you for that great new table you're supposed to already be done with) then, you go out and get a nice jointer.
But by that time, you'll be on your third router (for small stuff), your fifth hand plane, your second set of batteries on your cordless drill and impact driver, and your second table saw cause that Rigid is nice but not as nice as a cabinet saw :)
Rob Kress
Oh yea, forgot the sliding compound miter saw!! Whoo Hoo!
Buy used (craigslist.org). If the machine is in good shape, you'll save hundreds. In my area, I'd expect to pay 100 to 200 for a lunchbox planer and 200 to 300 for a good closed-stand 6" jointer. There are usually a bunch available so I wouldn't want to pay any more than 50% to 65% of the original value.
On the jointer, 6" is pretty common on the used market. This is because many people out-grow them and move up to an 8". On an 8" jointer, you'll only gain 2"... but the tables are almost twice as long, which is well worth the cost. Expect to pay $600 to $1200, depending on the maker and condition.
IMHO, a jointer and a table saw are always better if you buy big. On the rest, buy the best you can afford.
if you are going to be working with rough lumber, a jointer is a must and also when working with homedepot type lumber
a decent used 6 inch jointer will do the job for 2 to 3 hundred bucks, jointers are simple machine and a good one will last forever
a lunch box planer is much more complicated so buy a new one, the dewalt 735 is on the top of the pile
i also use a ridgid 3650, its no cabinet saw, but a great saw for a hobbiest/small pro shop
Thanks all of you for the information. It'a always nice to get opinions from real people instead of just searching the internet and not knowing if someone is being honest, or just trying to sell you something. Unfortunately my hours at work got cut a little, so my purchase will probably need to wait a while. The joys of a recession!!
Well, I had a Robland combination J/P with a mortising attachment. I sold it when I moved to a larger shop, WRONG MOVE. I regret that choice all the time. In fact, I have a nice Boice-Crane jointer and a Rockwell-Delta planer I’d let go….
For me at least the combination is the way to go.
