WITCH IS THE BEST TIP OF PLANER KNIFE’S FOR MY 15” PLANER ANY SUGGESTION
use the ones sold by the manufactorer.. They will fit and function as intended.
That's going to depend on a number of factors. What brand of planer are you using? What kind of planing do you do; how much; how often?
Assuming that all different options available for your particular machine, you could consider:
1. High speed steel. Relatively inexpensive, $60 - $85 per set and can be resharpened many times. Replacement can be difficult and time consuming.
2. Disposable blades. Initial investment is high, about $250 - $350, but after that you can use inexpensive high speed steel (about $40 per set) or even cobalt knives (around $75 a set). These are easy and fast to replace, but the knives cannot be sharpened.
3. Spiral cutter head with replaceable carbide inserts. Not sure if you can get this system for a 15" model. Gives a very smooth finish with little or no tear-out, but it's very expensive.
