For the last couple of years I’ve been using the cheapest planer I could find (the portable Delta 12 1/2 inch) that I bought at Lowes for about $200. Generally speaking I’ve been reasonably pleased with the planer but snip is a continuing problem and the dust collection situation is not the best. Delta has another planer that is described as a 13 inch, 2 speed finishing planer that sells for about $400. It has a locking head which supposedly cuts way down on the snip. I’ve started using more hard wood that has not been planed which means everything I work with will have to be planed, so I’ve decided to move on to a better planer.
I’m ready to type in my order but I’ve learned to seek opinion on this sight before I make any final purchases. You guys have kept me out of trouble in the past. Your thoughts would be welcome.
This is what I have: http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=39860
and I'm very happy with it. Main disadvantage is weight; I built a roll-around stand for it. I chose it mainly for the large table.
ne sutor ultra crepidam
Dang, HF has some inexpensive stuff.
I know a few who are happy with the Dewalt 735. Get the optional tables.
Edited 11/30/2007 6:11 am ET by TWG
Just some food for thought. I'm probably in the minority, but . . .
I use a DeWalt lunchbox (734?) planer. It has a locking head. I used the lock exactly one time. It's simply too much bother to lock the head on each pass. Instead, i control snipe by making sure the knives are sharp, keeping the bottom table free of sawdust (the DeWalt bottom table is sheet metal over the base & sometimes sawdust gets between the layers), taking a fine cut on the last pass or two, and feeding the stock by holding the end up a bit at both the beginning and end of the cut. (This works best when My Lovely Assistant is at hand to either "pitch" or "catch".)
On this planer, I find snipe to be caused more by the board moving up into the blades after it passes the infeed roller than it is by the head moving down. I don't really have much of a snipe problem with the above methods.
Point being, don't think a head lock will necessarily cure your snipe problem.
Mike Hennessy
Pittsburgh, PA
I have the planer your talking about (the 580) and its a great planer, but won't solve your problem. The snipe is a little better when lockin. But I never use it. I always lift a little as the board comes out and this seems to have solved my snipe problem. I don't lift and I get snipe.
I would save my peenies and get a 15" or bigger planner. Especially if you plan on using more rough cut wood. The larger planers are capible of taking off 1/16 in a pass or more. where the luch boxes 1/16 is the most I would do in soft wood.
Woodman,
I'd recommend a Marcou, or possibly a Holtey.
Mel,
Do either of those come with a spiral cutterhead?
:>) Paul
Paul,
They both do, it's the one behind, pushing the plane! :-)
Not meant in Mels general direction; it's the feeling one gets when they see that beautiful thin gosamer shaving.
Edited 11/30/2007 12:46 pm ET by KiddervilleAcres
Of course. Dummy me. I forget I used to have curly hair.
Paul
Woodman880
buy the Grizzly 15 inch or the 20 inch.. it will be working for you decades from now whereas the others will be junk inside a few years..
I have the Ridgid 13" model and I get snipe also. So far, I've lived with it, but I recently decided I want the ability to make small thickness adjustments after glueup where I might not have the extra two or four (back end) inches to waste. There is a FWW article that describes a bed you can make out of engineered wood and lift a bit on either end to eliminate snipe. Haven't tried it yet but its on my todo list.
I think there were two articles but here is one of them. Might be cheaper than buying a new model if you're otherwise happy with the one you've got.
http://www.taunton.com/finewoodworking/Workshop/WorkshopPDF.aspx?id=25269
Andy
"I have the Ridgid 13" model and I get snipe also."
Use the adjustment screws on the outfeed table so that the table is angled ever so slightly above the plane of the bed. Works for me.
Edited 11/30/2007 12:57 pm ET by saschafer
If its snipe that is the problem and not the width of the boards your planing or the quality of the planers cut, there are few things you can do to reduce snipe. One is check the adj of the infeed/outfeed tables, another is to get a piece of melamine cut it to the exact width of your planer and brace it on both ends to stop the snipe. There are more. I think there is a article or video on this site about just that reducing snipe.
here is a article
and
http://www.taunton.com/finewoodworking/Workshop/WorkshopPDF.aspx?id=2416
hope this helps
Edited 11/30/2007 8:50 pm by Sancho
