I have a dewalt 735 planer and am looking for plans for a mobile cart with outfeed tables.
I saw one here but want something smaller and with out storage.
Thanks,Mike
Thanks,Mike
Mike: How about something like this.
One link I found. There are others... The bekow link is not for a 735 but maybe something you could think about?
http://www.ncwoodworker.net/forums/f81/mobile-base-48-out-feed-tables-15-planer-27911/?highlight=planer+table
You stated 'without storage'.. I wonder why? You have to make the base anyway and inner shelf(s) would make the base stronger.
Mine is nothing like what you will see at the above link. I use two roller stands for input and output support that are not part of my roll-around for my 735. I saw no need to put outriggers that are part of the planer stand. I used 1/2 inch plywood and planned quality construction 2X4. I always make my stands (other tools I use) with 4 swivel (LOCKING) casters. I never liked two swivel and two non-swivel casters... They do not work well for moving things around in a very small shop.
Anyway, I would suggest that the adjustable seperate roller stands are a better option as they can be used for other tools/needs. I have not looked inside of the link given.
I would also suggest that the output support roller(s) be adjustabe and not a flat table. Some 'sticks' warp and twist during planing operations. Even quality woods you may use... I think you need 'support' but whatever that support is, it should only hold up the wood as the end of the board nears the exit of the cutter blades...
And, you can never have too much storage space! Maybe you just wanted to say you did not want the expense of doors on the storage space?? Not sure.....
al
