Hey guys, I recently built a nice new fence system for my router table with adjustable/removable faces made of melamine ontop of a sturdy MDF fence.
I wanted to go ahead and build a jointing face for the table as well knowing that the two peices on either side of the bit do not stand flush with each other, ie the outfeed face needs to be proud of the infeed face by a 1/16th or so to get the proper effect, and instead of trying to figure out how to shim that face out a 1/16 I was thinking of making a second infeed face that’s 1/16th less thick than the outfeed face.
To do this i was gonna take a piece of melamine and have a friend put it through his planer but I don’t wanna mess up his blades if you shouldn’t be planing melamine.
So my question to you is can i put melamine in a planer without damaging blades?
JD
Here' are some pics to see if they help you get the gist of what i'm talking about.
Oh, and ignore the crappy tablesaw pictured to the left, i mean to replace it this year with a new Xacta from Jet if i can find a way to fit one in my shop.
Edited 6/17/2003 11:20:55 AM ET by JDorn
JD, Melamine is simply a coating on the main stock. I don't know what it might do to the planer blades, but the melamine itself will be a mess if you plane it, and it will be gone. For shim stock, go to your local Ace or whatever and find the area where they sell brass tubing and small brass sheets for hobbyists. You will find a variety of thicknesses, and should be able to get a piece that will fit your fence.
Edited 6/17/2003 12:20:48 PM ET by forestgirl
JD
Option two is to make the out-feed side 1/16 thicker. If the infeed side is 3/4", use a piece of 3/4" MDF on the out-feed side and laminate a piece of 1/16" formica to the face. Or if you have a removable fence face as I do, you can just slip the piece of 1/16" formica between the out-feed fence base and the front sub-base.
I just bough a jointer about a year ago. Guess how I jointed till that time? Works like a charm for edge jointing.. ha..ha..
sarge..jt
Sarge, that option #2 is the one i'm thinking about now i guess. Yes the faces on my fence are removable, they just ride on some bolts that engage a piece of aluminium T-Track on the other face of the fence. I guess i could just get some laminate or formica and stick it to the inside face of a spare fence block, then i could just interchange the faces when i need to joint.
but yes, edge jointing does work quite well with a router table, much better than i'd anticipated, even with my even faces i'm able to get very good joint lines, though the uneven face does cause me to snipe on the end of the cut every time that's why i'm trying to figure out how to make a jointing face.
JD
Sarge is right, just shim the outfeed side and you'll be much better off. I've never planed melamine, but I've sawn a lot of melamin on my bandsaw, and it's murder on blades. Between the actual melamine coating and glue in the particle board it destroys blades.
JD
You could make a separtate fence, but it's easier as you've figured out from my an other post to just loosen the bolts on the out-feed and drop in the shims. That way you don't even have to remove the fence.
Sometimes, simplier is better....
sarge..jt
Shims are the way to go(as already said). If you want cheap ones that are thickness adjustable . First beer can aluminun and then sheets of typing paper for thin ones . It works you can get any thickness necessary with minute tolerances.
Philip
P.S. I learned this from a guy who deals in used woodworking machinery.
hmm, me thinks i could probably find a rogue beer can or two in my shop.
JD
I would strongly not recommend running Melamine through anything with rotating knives. If you need to thickness melamine and the other ideas already mentioned than find somebody with a thickness sander and go that route.
I only wish I took a picture of my buddies thickness planer after he tried the same thing.
Scott C. Frankland
"This all could have been prevented if their parents had just used birth control"
JDorn,
I'm glad to see that there is at least one other guy with a weed wacker hanging proudly next to his woodworking equipment!!
