Hi Folks,
I’m starting to get “into” dovetails and wonder what is the best way to clean up the ends of the pins and tails that are proud of the box side.
I’ve tried a sharp chisel with ok results. 🙁 It just take 1 dig to mess up the side. Should I be using a plane?
thanks
Tom in NC
I reach for my low angle block plane for this job.
Tom,
As Doc said and/or a sanding block wrapped with Norton 3X sandpaper.
Hi Tom ,
Here is a veritable treasure trove of info on the subject.
http://forums.taunton.com/fw-knots/messages?msg=44964.1
roc
Edited 8/8/2009 2:20 am by roc
"Here is a veritable treasure trove of info on the subject.http://forums.taunton.com/fw-knots/messages?msg=44964.1"
YES THAT IS QUITE CORRECT. The op must ofcourse pay particular attention to message #11 (;).
By the way, Rocky, the use of an electric soldering gun to demagnetise is quite effective-thanks a lot for the tip.Philip Marcou
tom,
A wider chisel will be safer as there is more blade to register onto the surface of the piece you are paring down to. It's easier to keep a wide blade laying flat, plus you can cut with a slicing motion rather than simply pushing the edge thru the wood.
If there are just two or three pins to trim, like for a narrow drawer, I usually reach for the chisel (always a chisel if the drawer is lipped), if its a wide case end, I usually grab a plane.
Tom,
Cut the pins and tails a hair short and trim the LONG GRAIN down to the END GRAIN, not the other way around. Either way, a sharp block plane does the trick. Work towards the middle to prevent blowout.
and www.flairwoodwork.spaces.live.com)
Now dat iss not goot , Chris,
because it is avoiding something which you should have no fear of doing anyway, plus, if taken literally, it means that you are not going to take a shaving or two off the pins (end grain)- which needs to happen a) to set some tolerance in drawer fitting and b) to remove glue which for sure will be sitting in the end grain.
And if you have lots of drawers to do this will take up extra time and effort-and if if you have carcasses to clean up it will amount to ACRES of extra planing which could also interfere with the desired thickness of the case.
Why the paranoia over planing end grain? Who knows, I don't.Maybe it is because folk like to use small planes like #9.1/2 block planes instead of something with some heft-like a #5.1/2, #4.1/2 or a low angle jack plane?
Philip Marcou
It no worky, Philip? I'ze a done it botha ways. I hava no preference really and act-u-ally aim for everything to be even. Of course this never happens, so perhaps half the times the pins are low and the other half they are proud! But then sometimes they are right on. Sometimes. Me ain't much of a drawer-maker and I'ma just gettin' into dovetailin' agin. But when I do make drawers, I do like to go for that sweet, piston fit (y'know, the one where you feel the air rush out as you close the drawer).Why the paranoia over planing end grain? Perhaps it has something to do with sharpening. We both know how to sharpen a plane so it will shave end grain, even with a high-angle of attach. But that's not the case for everyone. About seven years ago, I sharpened my tools with a mill file. Seriously. Bear in mind that seven years ago, I wasn't into as fine of work as I am now. I was also 14.Chris @ http://www.flairwoodworks.com and http://www.flairwoodwork.spaces.live.com)
Hi Chris,
Don't build too many lipped drawers, do ya?
Of course not Ray - the lip makes it too hard for the air to rush out. I like my insets.Chris @ http://www.flairwoodworks.com and http://www.flairwoodwork.spaces.live.com)
Like Ray, and others in this thread, I use a chisel. There really should not be much of a chance for a "slip." Perhaps you should tell us more about your chisel technique. For what it's worth, the back of the chisel should be registering on the drawer side. You then sort of swing the chisel in a arc to slice away a bit of the proud grain at a time - it doesn't take long. You may need to reposition the chisel when you get near the edge to prevent breakout - i.e., slice in from the edge rather than letting the end of your stroke be out in the air past the edge of the drawer or carcase.
I tend to use a LA Jack, diagonally across the board, working from both outsides inward.
