I am making a bed out of quarter-sawn white oak. Yesterday I jointed and flattened the rails of the bed on my jointer/planer. Since the oak was figured, I moisened the wood before I began.
After running the boards through the machine, I was distressed to find that the wood had darkened, particularly the “rays” of the white oak.
Any ideas why this happened and what can be done about it?
Tenderfoot Bob
Water, iron and the tannin found naturally in the oak combined to give the black staining. Assumimg the staining isn't deep it will, or should, plane, scrape and sand out at later stages of the production. Slainte.
richardjonesfurniture.com
Thanks Stainte. The reaction of tannin with iron was something that did not occur to me and explains why wetting down maple for planing for another project did not result in stains. Again, thank you so much.
Tenderfoot Bob
I'm curious to know why you felt it necessary to wet quarter sawn oak with water prior to flattening it. I can think of no reason to do so if the wood is normal, and working conditions are also normal.
Unless there is a compelling reason to wet the wood that I am not aware of I suggest you work the stuff dry for the rest of the job. Slainte.richardjonesfurniture.com
The quarter-sawn white oak stock I am using for the bed project I am making, is highly figured and thus much of the planing is necessarily against the grain. I have used, on the advice of "Knots", the light wetting of similiarly figured hard maple boards to soften the wood fibers to successfully avoid tear-out.
Tenderfoot Bob
Did you initially try planing the wood without wetting it first? And if you did, how bad was the the tear-out and did adding water help?
Instead of using water you could try white spirits, aka mineral spirits in North America. One advantage of this is that you don't get the staining you experienced, although the smell is nothing to write home about!
Additionally there are other factors that can exacerbate tear-out, such as:
too heavy a cut
dull knives
feeding too fast
One technique you can use that will sometimes help reduce tear-out during both surface planing and thickness planing is skewing the cut. This seems counterintuitive because skewing effectively reduces the angle of attack of the knives which really should increase the likelihood of tear-out. It does however also mean the knives take more of a cross grain cut; and the technique loosely emulates the old trick of hand planing difficult figure, eg, ripple figure, across the grain to reduce tear-out.
In any case if you have now successfully planed all your wood for this project the information in this post is probably of no help, except perhaps for a future project. Slainte.richardjonesfurniture.com
And, as I said in the other forums you posted in, if you need to apply water to a wood high in tannin, only use distilled water. The minerals and metals in much water will react with the tannin and cause dark stains.Oxalic acid is the bleach that removes these stains.Like Richard, I too question the application of water to "soften" the wood surface. Water is sometimes used on highly figured wood like curly or birds eye maple but oak is not a wood that tends to need that type of treatment.Howie.........
