Hi to the group,
I am resawing some hickory and have about 3/8 inch leftovers that I want to plane.
Is there a safe way to plane thin stock? Some time ago I read something about a sled for a thickness planer.
Any help would be appreciated.
Jim
Hi to the group,
Jim
What about a good hand plane?
jmac,
I just take a piece of melamine about 5'long and lay it on the planer bed. Attach a cleat on the underside such that it hooks on the planer bed edge keeping the melamine in place....then just run your stock thru.
Dear Jim,
I have a Makita 12" bench-top planer that will plane down to 1/8" with no trouble. The only thing is to take lighter and lighter cuts as the piece gets thinner. 3/8" or a 1/4" is easy and yields consistent results.
Best,
John
With something that thin, be sure you're wearing your safety glasses, and position your body to avoid anything that goes "boom" in the planer, flying out.
Thanks to all,
I'll do experimenting and let you know how I fare!
Much depends on the dimensions of the stock. For small I use double sided tape as a hold-down to melamine and hand plane or pass under my drill press Wagner Safe-T-Planer. Large I still stick down but make a carrier for the thicknesser. dampening the surface helps prevent break-up.
I like the stick-it-down idea but don't forget orientation. You want the grain sloping backward. Sometimes the grain is all over the place in which case you'll be out of luck. But there's usually a 'best' direction.
While thisis for planing thin stock for line inlaying, the idea works for other things as well. Because the stock is sprung just a bit on the jig, held between two cleats, you don't need double back tape - and the fun and games of getting it off thin stuff. Thank Michael Fortune for this little gem
http://web.hypersurf.com/~charlie2/InlayingLine/Inlaying2.html
charlie b
