Greetings,
I recall an article detailing a step or stepstool that had a tall back to be used as a handle. It was made with a tapered dovetail connecting the top of the step to the back. The author was a professional woodworker and said that he made these steps for cusomers as a present. I was thinking that the article was in Fine Woodworking and I was thinking it was by Sam Maloof or possibly by Tage Frid, but I could be wrong about any or all of those recollections (I do however recollect the article).
I have searched the index and done a cursory search of my copies of Fine Woodworking and cannot find the article.
I am planning on making a step like that as a gift and would love to reference the article.
If anyone knows of this article, I would greatly appreciate a nudge in the right direction.
Joe
Your mention of Tage Frid may mean you are recalling his three legged stools with dovetailed backrest and handhold as shown in his book 3 T F Teaches Woodworking, 1985 Taunton Press!
Library may be best source. Hope this helps.
Can't help with the article, but I've made a couple like this. It's not what you're thinking of, is it?
http://www.cohassetcolonials.com/cart/detailed_item_listing/431/87
Actually, it is very similar. As I like to say, it is exactly the same only different.It is precisely this type of step. The design was a bit different. I had started my design and rough cut come of my lumber, however, after seeing this I am thinking of making a few changes to the design. Thanks for the response, you have given me some ideas. I was concerned that my design was too klunky. By modifying this I think it will look great.Thanks,
Joe
A photo with major dimensions goes a long way. Sorry I can't remember the source of the plan I used, but that was 20+ years ago. Mine did not have the little loop around back of the upright part, but it just became one of the dovetails with it's long taper.
joerabbi,
I made a few for family which have been received quite well. They are used in the kitchen to reach the higher cabinet shelves. The depth is 13" and the width is 14"...the height of the step most liked is 5". I've integrated a turned handle (36" long)into the base.
The dimensions provide a solid base for both feet and butts up against the counter top. The step up is easy to handle. I made it as light and strong as possible.
What you describe seems to be a "pouting chair". It was actually a step stool with a tall back with a slot cut into it to serve as a handle. These served double duty for naughty children to sit in for time outs, hence the name. An example with working drawings may be found in "American Country Furniture" by David T. Smith. Rodale Press. Try your local library. I bought my copy at a flea market and it is loaded with a wide range of projects with step by step detailed drawings.
Here is a list of magazines/books that contain references to a chair
