I am interested in finding out how louvers commonly found on plantation shutters are made. Most manufacturers refer to them as elliptical shaped. Can this be achieved on a router table profiling all sides in four cuts. My concern is that once you have machined the one side of the louver and turned it over it will start to rock as you feed it through the cutter. Is there any other way of doing this?
Such profiles are easily made with molding machines. To imitate them on a router table would require some jigs to prevent the rocking that you wisely foresaw. I would suggest profiling two sides of one edge first and then inserting that side into a sort of vee shaped jig cut into thicker stock. The jig then could provide reference surfaces for the profiling of the remaining two edges. I would likely tack the workpiece into the jig with a few screws.
Clay
I was at the woodworking show in sacramento in april and can upon Woodline USA's 5 piece shutter bit set that included a packet of 50 louver pins for $60.00. They also included a very well written instruction article from a magazine that shows how to build and make all the jigs to complete the shutters. I already had 4 of the 5 bits only lacking the profile bit for the louver portion but they did not have it for sale alone, yet. Additional louver pins sold for $5.00 per 50. I have several arched louvers to make so it didn't take much to sell me this set. Hope to get to use it soon.
Are you sure they're truly elliptical? The ones I've seen are more like rectangles with rounded ends. You could easily make them on a router table.
