Hello, Please someone HELP ! I make the finest hand cut dovetails but I can not hand chamfer a box lid panel to fit well. No matter how careful I am with the hand plane, I can not get the angle right so the lid panel will fit into the dado all the way around 4 sides without leaving an unsightly and distracting gap somwhere ! How did the old timers do this ?
Dave.
Hi,
I think the old timers didn't care about the gaps in their panels. It sounds crazy but I think it has to be true. The reason I think this is so is that I, like you, can't get those gaps perfect. You are trying to make them perfect. I gave up trying a long time ago. I use rabbeted panels. I like the shadow line and I don't have that issue of gapping. If I want a beveled panel, I still use a rabbeted edge to fit into the frame. This way my fit is perfect and I still have the beveled edge. Good luck with your struggles. Gary
Thanks for you reply. I think you are right. But, because I don't want to look at any gaps in my work I bought a vertical cove bit for my router today. It's funny that I can cut beautiful dovetails by hand but I can't ( after 3 careful attempts ) plane an angle on a piece of wood so that it is the same all the way around. Maybe if I practiced a few thousand more times ( like I did when I was learning hand cut dovetails ) I will improve but, the router bit will have to do for now. It took me 7 years to perfect my dovetails and I don't have an unlimited lifespan to learn how to do everything by hand.
Cheers !
Dave.
Dave,
I have that same vertical coving bit. I also have a jointer and a planer. Pick your battles. As Sun Tzu would have it, the victorious general has a strategy that guarantees victory before the battle begins. This almost explains it. Have fun and good luck to you. Gary
