I’m turning a table lamp out of black palm and holly. My problem is making the mortise on the top (shaft) to mate with the bottom (bulbous base). No matter how firmly I tighten the chuck on the headstock, when working the free end, the fibrous black palm tears out of the chuck.
Unfortunately, I can’t use a screw plate mounting because I’ve already cut the wire chase down the top (shaft). It would seem that I need to attach a hardwood mounting to the shaft, but I can’t figure out how to release it. That end will become the top of the lamp where the socket is.
Thanks in advance for any advice you can give.
That will be a very attractive lamp!
I would not fight it but route the mortice instead using a home made guide.
I may not be understanding the situation. But it seems to me that you can simply glue a hardwood plug into the center-drilled wire chase and use it with your screw center. It would be a simple matter to drill out this short plug when the turning is complete.
