I have some partially used sheets of 3/4 inch plywood. Is there any way I can tell if they are exterior grade?
Unless you've managed to have unlabelled scraps left over, it should be stamped somewhere.
Don,
The adhesive used to glue together the layers of exterior plywood is dark brown. The interior adhesive color is noticeably lighter.
Dan Kornfeld, Owner/President - Odyssey Wood Design, Inc.
Thank you. You are the only respondant who didn't tell me to look for the label on the back. Obviously , if I had sections of wood with a label I wouldn't have had to ask.
Don, my apologies for stating the obvious, but this was your very first post, it wasn't explicit as to labels, and there was no way to know whether you were a tender newbie or not. No slight intended.
Again, my apologies, welcome to Knots. Now you know there's a reason we call ourselves Knotheads!!
Edited 3/30/2003 11:07:01 AM ET by forestgirl
