Is there a document somewhere that lists all of the markings and ratings for plywood? Like how do I know if a particular product is void free? Or no seams in the face veneer? And the true dimension?
Try this link. If it doesn't work let me know...
http://www.apawood.org/level_b.cfm?content=prd_ply_main
You have to register to download the different technical documents, but registration is free and so are the documents for download.
JJ
Edited 2/28/2006 12:58 am ET by Jumpman
Cool site! Thanks!
Do APA standards apply to cabinet grade and hardwood plywoods? I think the APA is generally concerned with construction grade products.
THe APA deals with softwood plywood.Hardwood plywood can have a number of cores and faces. Typically the hardwood plywood I have dealt with is graded A, B, 1, 2, 3 ,4. For example A1 would have an A face and a number one back. 4-4 would be a paint grade hardwood plywood with numerous fills. There are other grades in the industry. A good website is http://www.hpva.org/Another is at http://www.highlandhardwoods.com/hardwood-plywood.htmlMany companies will have proprietary grades made for them instead
If you need plywood guaranteed voids free, the only one I know is Broun zeel (not so sure of the spelling) the outside veneer is African mahogany, it is a marine grade, on the expensive side, with a great variety of thicknesses (metric) down to the aircraft size (2 mm ?) Great stuff.
C.
Brunzeel is the proper spelling.
C.
Hi Bryan ,
Plywood cores also have a grading system . Apple Ply is about as void free you can get for a multi plied panel , usually with a Maple face .
Another product often sells by the name of Armour Core , much of the on grade hardwood plywoods come with a layer of MDF or similar under the face of each side eliminating any core voids under the faces .
Lastly Baltic Birch or as we used to call it Fin Ply , in the old days it was one of the only products I ever held that said made in USSR .
good luck dusty
