I have made a number of “Mission/Arts and Crafts” style pieces in the past . Mostly by hand (UGH)! I am starting a project for a client which involves quite a few different pices. I am going to use my new PM 719A mortiser. Anyone have some lessons learned about allinging the mortises on something like a “Stickley #516 Encyclopedia Table” or other like pieces? Thanks for anything you can pass on!!
Just be careful and precise doing your layout. I would make a full size mockup showing the locations of all the mortises before doing any cutting. Work from the center of the rails out to the ends, so that if you have to fudge a little due to an error in sizing parts or measuring you can make the last spaces equal to each other. There are a bunch of mortises on that piece, and you don't want to do all that work twice.
Bob Lang
http://www.craftsmanplans.com
Bob, it is your great book and large scale drawings that generated my question. Can't wait to get to work. Peased to have you personally answer my question.
Jon Cummings
Ocean Springs, Mississippi
No Problem-hope you enjoy your new mortiser-let me know how it turns outBob Lang
Cut all your through mortises from the finish side in, use a high quality, well tuned mortising chisel and auger bit set (Clico or Fisch) and use scrap oak for backing up the cuts. Clamp the work down for each cut, don't count on the hold-downsIf you get any minor splintering on the bottom of the cut, it will be covered by the tenon shoulders. Measure three times and cut once!
