Pneumatic Drum Sander used by Christian Beckvoort
I have not seen what Chris Beckvoort uses but drum sanders are not to pricey, 50 to 100$ or so depending on size, sleeves etc. Lee Valley has them. Likely less $ in the states I would expect then up here in Canada.
Thanks, I didn’t even think about looking on Lee Valley. I looked on Woodcraft, Rockler, and Amazon and not much there. I’ll check LV.
I just noticed I left off the “s” in Becksvoort. Hopefully he won’t see my mistake.
Take a look at Klingspor's Woodworking Shop as well. And Grizzly.
Thanks John
Hello all, I finally located the pneumatic drum sander. I bought it from Industrial abrasives. They sell a model for lathes as well as for drill presses. I have used it several times now and it is a huge time saver and much easier to use on curved surfaces.
https://www.industrialabrasives.com/sanding-sleeves-industrial-abrasives-airfilled-cushion-contour-sanders-c-77_101.html
Which size did you get?
