I’ve got a client who wants a cabinet for a 55″ tv and would like pocket doors. By the time I build for the tv and space to put doors I’m almost to 36″ wide doors. Does anybody manufacture hardware to accomadate this size door? The closet I’ve found is KV”s 8092.
Thanks for your help.
Dale
Hey Dale Jr.
I did some Google searching and mostly maxed out at 24-in.-wide capacity hardware from Accuride. Then I came upon a thread over at Woodweb.com, which seemed to offer the answer you're looking for. According to that site (link below), Accuride offers an extension kit for one of it's pocket-door hardware kits, and a company called Hafele also sells them for a high price. I scoured the Hafele site and couldn't find anything bigger than 24-in. so I would just call that company and talk to a human being.
http://www.woodweb.com/knowledge_base/Designing_for_Large_Pocket_Doors.html
However, I got to thinking about your design task and I wonder if you should discuss some other options with your client, like a tambour door or some other creative idea? You may be able to find something that is less expensive and more simple to install.
Here's an article on tambours: http://www.taunton.com/finewoodworking/SkillsAndTechniques/SkillsAndTechniquesPDF.aspx?id=2728
Plus, to accommodate a 36-in. wide door, the cabinet is going to have to be about that deep. Assuming that the 55-in. tv is a flat screen, it's seems like a waste of space to make the cabinet that deep when it could be 12 in. deep. But that's just my opinion.
I can put in a call to an author of ours who is a real entertainment-center pro if you don't have any luck with the leads above. Just let me know.
Matt Berger
Fine Woodworking
Edited 6/13/2007 8:36 am ET by MBerger
Dale—
Assuming you’re dealing with a flat-screen TV and a relatively shallow cabinet, I’m with Matt on this one, Dale.
Tambour doors are a good idea, and worth looking into. Keep in mind that tambours can also retract vertically, either down and into the base of the case, or up and into a soffit area, which is just a hollow box at the top of the case.
Another idea is to use bi-fold, or even tri-fold, doors, and engineer them to either fold back into the case or on the outside.
Good luck!
—Andy Rae
