Today’s reproductions of Shaker oval boxes almost always used wooden pegs (half a wooden toothpick) to secure the lids and bottoms to the bands. Studies of Shaker originals often identify “points” as securing the lids and bottoms. Anyone know what “points” are? I’m guessing they are a headless nail, but I’d rather not guess. Were they different from today’s brads? Thanks.
Boxes
Those boxes are held together with copper rivets.
They are hammered in place -
SA
SA:
I've built perhaps 35 boxes now and you are correct - the bands are held against themselves with copper tacks. The lids and bottoms however are separately secured to the tacked bands. Some of the originals I've seen discussed were said to have the lids and bottoms attached with "points" , as in Shaker Woodenware: A Field Guide Volume 1 by June Sprigg and Jim Johnson, pp. 28, 42, and 44.
Boxes
Hey Don -
I have only made two Shaker boxes so you are more up on it then I am. The bands I attached with copper tacks - hammering them into a rivet. The top and bottom I attached with headless pins. The same pins the floor guys use -
It worked - not sure if it was historically accurate ? The boxes I made are now 20 years old and they are holding up - no cracking - no pin pops - seems to have survived the test of time.
I guess you can use toothpicks but the hole will be bigger - not sure if I helped out here but I enjoy contributing -
SA
guessing not allowed?
I know you're looking for a historically-accurate description, but I'm going to guess anyway. ;-)
My guess would be that "points" were small headless cut nails - something that could be easily produced (by hand) in a "shoppe of yore".
