I have trouble getting a smooth finish when putting shellac on a table top using a brush. I would like to steel wool the shellac finish and over spray it with polyurthane (fast drying) but I am afraid that might mess up the whole top. Is the poly compatible with shellac?
Here's what my Zinsser Shellac can says: DON'T use under polyurethane....
Julien the happy woodworker
At least my workbench understands me...
So, I don't see the point. Is there a question?
Zinsser shellacs contain their natural wax which means that waterborne finishes and oil based polyurethane finishes will not adhere well to it. If you use those finishes you must use a shellac that has been dewaxed. Zinsser makes a product called Sealcoat. Sealcoat is a 100% dewaxed, 2# cut of blond shellac and can be overcoated with waterborne finishes and oil based polyurethane.Howie.........
Thank you for the info.
I just read the small print on my can of Bulls Eye Shellac and it says "don't use under polyethane finishes"!
When all else fails read the directions.
If you want a varnish top coat you can use a traditional resin varnish over any shellac, just no poly. The traditional resins (alkyd or phenolic) will be clearer than the poly anyway.
