I am refinishing a church pew for my wife, and I have a dilema with the polyurethane. We are using oil base Poly and the back portion of the pew has remained tacky for several weeks. The entire pew has one coat of finish that was put on at the same time, but only the back has done this. The seat portion dried quickly. The entire pew is the same type of oak. What could cause this and how can I correct it?
In refinishing, did you strip the pew down to raw wood everywhere? Because the only thing that I can think of is that there was something on the back of the pew that the polyurethane reacted with and interfered with its curing. Wax is an example.
Yes, the pew was sanded back to the raw wood. However, the finish that was on there looked like it had been re-done more than once. I guess something could have been applied to the back only (seat cushions on the bottom) that impregnated the wood. How can I remove the poly that I put on the back and attempt to "resand" it?
I don't know if this is the best way, but I would apply a stripper that works on polyurethane (I'd use Bix Tuff Job) and scrub it thoroughly with mineral spirits to remove any residue. This process will also get any filler out of the grain, which may be contributing to your problem.
Sanding rather than using a chemical paint remover can be problematic. Sanding frequently does not get deeply enough into the pores to remove all the finish and other gunk. This is particularly a problem with large pored woods like oak. It is best to always use a chemical stripper.
At this point, I would remove the finish you have applied by using a paint remover containing methylene chloride. It is the one with the longest list of cautions on the label but it is the one that will remove all gunk and old finish. Follow the directions and you will be fine.Howie.........
Wax is an example.I sort of agree.. I just did that with Spar Varnish over Shellac.. Not de-waxed...Took forever to dry... I had a floor fan on it for a week! Finally dried and I think it has adhered well even with the wax in the shellac...
