i’m from ireland, and am bout to buy some US windows for my home, but to trim around them, i’ll need a close match for the ponterosa pine their made from. we can only get eastern white pine OR southern yellow. which would match up best?
appreciate any suggestions
good stuff
Eddie,
Eastern White Pine and Southern Yellow Pine are the only choices, huh? That being the case, I personally would go with clear, vertical grain Eastern White; if you can get it. Are you planning on using a stain or finish natural?
Dano
*dano, i could use a stain if you have a suggestion!
*Eddie,To stain or not is pretty much a personal choice, if you do you will more than likely have to use a sealer first.Dano
