Can heart Poplar wood be used for making the top of a dining room table? Will it hold up like oak or walnut? It was cut down here in Florida where I live and has been stick stacked for over a year under cover. It is 4 quarter cut and some of the boards are over 15″ wide. Will I have problems using this wood that has not been kiln dried? Any suggestions? Should I forget about using this wood for a table top? I planned on using only the heartwood.I want to build this for a cousin as a return favor for giving me over 400 board feet of this wood
Lefty,
Poplar is pretty soft it probably won't hold up like oak or walnut fot a table top. It's good wood, but I think that it would dent and ding easily if used as a table top. I generally use poplar to frame paintings because it is light and finishes well and frames usually don't take alot of abuse. I am sure there are a multitude of other uses that poplar is good for.
Go to this website, they have a listing of applications that different species are good for. Good luck with your table, it sounds like a fun project.
http://www.woodworkersjournal.com/links_frameset.cfm?url=www%2Ehardwoodcouncil%2Ecom
Matt-
I would agree, poplar is rather soft, as hardwoods go, so it's more likely to be dinged and scratched if this is going to be a heavily used tabletop.
On the other hand, I really like poplar. Just because it's cheap and easy-to-work doesn't mean that it doesn't have a very nice iridescent quality when finished (but not stained). I like the colors of both the heartwood and softwood and the way they mellow over time.
David
What if you used the poplar as a sub-base and veneered the top with something nice. Also if you think that the table will take that much abuse then maybe you should consider other woods. I have some furniture that I inhereted and it has no dings etc. on it. It's a matter of how it will be used and who will use it. If there are kids involved use Oak. If it's to be used for dinning only by adults and that's it then veneer it. There are a lot of veneers out there and some of the oldest tables are done that way and still look good.
Try this site for veneers they pretty much carry everything and are a good source of info.
http://www.flamingoveneer.com
Terry
