I’m looking for some advice on the best woodfiller for poplar. I usually use Famo woodfillers and have yet to use their natural filler. Has anyone had any success with the above? What would be your choice and where can I purchase it?
Thanks and Work Safely!
Butch
Just do what you have been doing. It's fine and excellent. Brewing your own sanding dust with future finish and/or glue MIGHT be a little better but not worth the trouble. Famo,Durite,and plastic wood pays guys/(prolly chemicial engineers) to make it convienient for us. Just enjoy! Remember, time is money. If you have the time, be a woodfiller brewmaster.
Don
Rockhard Water Putty, dries to a natural finish. Looks like a fine wood powder, very close to a natural pine look, may work well for poplar. I have not used poplar with a natural finish, usually painted ,sometimes stained. If famo filler is not a good match, try the water putty.
mike
Enduro water-based pore filler is the best I have used; abundant open-time & very easy to use.
-Jazzdogg-
Poplar.. wash coat of Shellac and fine sand while still wet.. Make a slurry.. Leave the mess there... Let dry.. Sand and maybe again and again..
I have just about abandoned any kind of sandable filler, and instead am using Color Putty.
I have used lots of different brands (of sandable fillers), but over time, they all seem to break loose (from the edges of the nail hole) and pop out -- slightly, but still visible.
I am wondering if the rest of you have had this problem?
With the Color Putty, you generally end up with a tiny dimple, but at least it doesn't blow out.
I just finished a set of built in bookcases (painted), and I tried using an epoxy putty (Abatron). This stuff does a good job of moving at the same rate as wood (in exterior applications), so I reasoned that it would work better than a regular filler for these bookcases. But using it is more of a PIA.
"I tend to live in the past because most of my life is there."
-- Herb Caen (1916-1997)
