Antique chair carvings (ball/claw feet, chair crest rails, knee carvings, etc) seem to have their mahogany pores filled, like in the crest rail ears and shell on this chippendale side chair, https://www.diplomaticrooms.state.gov/objects/chippendale-carved-mahogany-chair/.
How would a modern carver do this? Working w/ African mahogany, with even more open pores than Honduran, seems to necessitate some kind of pore filler besides 10-12 coats of shellac build. I’m trying Aqua Coat, but curious as to what others carvers have done to not have their carvings upstaged by open grain.
Layers and layers and layers of rubbed in shellac.
Thanks John; have you done this yourself on carvings? it sounds a bit like french polishing without the pumice, which could work, albeit take forever and possibly damage my details.
I use a small sable brush that I use as my “fingers” in a French polish. Start by brushing on a 3 lb cut and allow to dry. Doesn’t have to be overnight just dry to the touch. Load the brush with oil, wipe off, wet with alcohol and add a smidge of pumice. Use this tool to work over the surface. Repeat the process. Add a little black to the shellac to “dirty” up the crevices. Eventually you will get the look you’re after. I call this French polishing with a brush.
Great idea John! That sounds much better than sprinkling pumice between shellac coats and rubbing out my crisp edges w/ a pad, which I tried with mixed results.
Found your video on the subject too, thanks so much! https://www.finewoodworking.com/project-guides/finishing/french-polishing-carved-details
