Porter Cable Template Guides Bosch Colt
Hello All:
I bought the Palm Router Subbase for use with Threaded Templet Guides – Model PR010.
So far I have not been able to locate the Porter Cable Template guides but I did try the Lee Valley 1-3/16″ Brass Template Guide & Freud Template Guides. Both of them did not fit the opening of the subbase. According to the Bosch website the subbase opening is 1-1/4″ however, I found that both template guides sat proud of the base (the Lee Valley one did not even fit properly).
Has anyone tried using the Porter Cable Template guides with Bosch Colt? If yes, any insights you can share.
LB
LB, I have the Porter Cable 690 fixed-base router, and the Woodcraft template guides work fine in it. I'm pretty sure the Freud's are a different size.
Update - I ordered custom subbases from Pat Warner http://www.patwarner.com and they finally arrived yesterday. Although I have not tried them yet, they came very nicely packed and the machining looks great. Would highly recommend Pat to anybody.
I ordered both the round and offset base for the PR20.
LB
