pos 4410l slide cannot be squared to fence thru wide cut
I’ve lived with this by never cutting wide boards and this saw has been a source of regret ever since i discovered the issue.
I’m wondering if anyone else has worked thru this yet. the fence cannot be adjusted enough to accomodate the crabbing or skewing of the saw thru the width of say a 12″ wide board. I have tweaked and justled and prayed and everything but cried and tossed this in a bonfire masde of of the wood I have wasted trying to get this thing to cut straight. I have squared the blade to the fence for a narrow cut and I’ve squared the fence to the blade for a widfe cut and several in between, but short some magic trick involving how the saw rides the slides, this thing is junk tomorrow. Thanks,
Bill
square and sorta-square
I don't have one, but you may be expecting too much from a tool that was intended for carpentry work. A 12" wide board is at the extreme end of the saw's capacity, essentially, where the slide is going to be least accurate.
The Bosch GCM12SD 12" Dual-Bevel Glide Miter Saw is spec'ed at a 14" capacity at 90°, and might do a better job for you. But, again, I don't have one, and can't attest to the amount of "slop" in the glide mechanism.
One alternative would be to work around the design limits by cutting a bit long, and then true the end of the board on a shooting board.
Another alternative would be to get an old, well-built Radial Arm Saw (Delta or DeWalt) for those wide cuts.
Or, you could go the Festool way.
Thanks Ralph. I agree. Usually I've used a crosscut sled on the t saw but hoped this expensive scms would do as advertised.
I guess for now I'll make a deeper sled. Now your shooting board idea is starting to sound appealing. That will let me test my sharpening skills. Yeah I've used this basically only for rough carpentry. This particular one isn't suitable for decent trim work. I've had it for years now. Just thought it was one of those lifetime purchases as its built like a horse. I'd built a small barn with it before I realized it was basically a lemon when it comes to exacting work. plywood gussetts hide a lot of slop :)
slop hiding
"plywood gussetts hide a lot of slop :)"
As does putty of various types applied prior to painting a joint. ;-)
"Shooting" a 12" wide board, though, could get interesting. Might require a Paul-Bunyan-sized shooting board and an extra-hefty #8 plane.
I wound up with a spanking new crosscut sled
Finished my speaker and amp cabinets. Square as a mason and not a too bad job on the finger joints.
The finger joints are another story. sheesh. I'd have saved two days in the shed if i'd have asked you earlier.
Thanks again and have a great holiday season. Mine will be a bit better thanks to you.
Bill
Bill, are you talking about the Bosch 10" sliding miter saw? You should be able to cut full width right on the money. It might help if you said more about what you have tried. Did you run a straight edge on the fence to see if it's straight? Do you know you have an accurate square? Did you buy it new or used? The more detail you give, the more someone may be able to help. What you are cutting, pull or push, using the clamp, type of blade, the original Bosch blades are junk but should still cut square if not that smooth.
