To Whom It May Concern; Can you please tell me where i can find info on attaching pictures on the Knots disscusion forumn? Thank You Chris Miller
Hi Chris,
If you are using a PC, there are two ways.
The first is to upload an image from your desktop using the "Attach Files" button located at the bottom of the edit window when you draft a message. It's the button next to "Spell Check." Once you click that, it will ask you to upload an image from your desktop. Then when you post the message the image appears as an attachment to your post.
The second method is to embed an image in the body of your post. To do this, the image has to exist on the Internet somewhere. Find an image, right click on the image with your mouse and choose "copy" from the list of options. Then navigate to the edit window and "paste" into the body of your message.
If you're using a Mac, the first option above is not available. Unfortunately, our forum provider doesn't offer full support for macs at this time.
Give it a try and let me know how it works out.
Matt Berger
Fine Woodworking
Thanks for the reply , will try it soon Thanks Chris
