Christian Becksvoort had a tip on removing Pine Pitch with heat.
I wonder if it also would kill the wood worms or Beetles in 3/4 Boards?
Hilmar
H,
You can rid infested wood or furniture of beetles in several
ways. Rough lumber can be kilned so that all parts of the
wood are heated to 150° for three hours. That should kill
powderpost beetles at all stages of their development. Interestingly,
high kiln temperatures may make the wood more attractive
to powderpost infestation later on. Above 113°, parenchyma
cells are killed quickly and their starch content is
fixed. Kilning below 113° depletes the starch and lessens the
food available to the insects. Even this wood, however, may
retain enough starch to support an infestation.
If you cut away badly riddled portions of once-infested sapwood,
you can use the rest of the wood. Be sure to burn the
sapwood cutoffs. A coat or two of a hard surface finish such as
varnish or lacquer should prevent any remaining adult beetles
from laying their eggs.
I've found one of the easiest and most effective weapons
against powderpost beetles is the pesticide lindane. Following
the instructions furnished with the product, mix a 1% emulsion
of lindane, and spray or paint it on infested wood or on
lumber that you want to protect. The emulsion will crystallize
in the wood and kill the beetles as they emerge to lay eggs. It
will also kill newly hatched larvae as they tunnel into the
wood. Lindane can be used on in-place structural timbers, log
cabins, barns, wagons and other outdoor objects. On old furniture,
it might be wise to apply the emulsion on an unseen
part of the furniture to see if it stains or discolors the finish.
After it has dried lindane is considered safe for use around
children and pets, but I wouldn't put it on lumber that will
eventually come into contact with food.
Sincerely,
Gerald La Starza
Fine Woodworking
Thanks Gerald, I will file the Information.The Box I have already, I used it for curing painted Models.
Hilmar
