Hi All,
I need information regarding running 3 phase power form 110 or 220 standard house hold power.
I have heard that Taunton Press has such an article but I am unable to find it. HELP!!
Wilson
Hi All,
Wilson
You need either a static or rotary phase converter. I use a rotyary converter from this place http://www.rotomaster.com/ I have had it in service for over three years and have been very happy with it.
Tom
Douglasville, GA
In Taunton Woodworking Machines book (that can be found on the books & vidios link above) they have a section in the book on how to build one from a used 3 phase motor.
I built one for my own use & use a couple of single phase motor start capacitors wired thru a relay to start it & a couple of small microfared motor run capacitors to balance the votage between the generated lag & the supplied legs due to i have one machine that has a mag starter swich that the heaters(c/t the overload protection) are sensitive to the voltage/total watts at full load.
Here is the link for the book that has the information your looking for http://www.taunton.com/store/pages/070037.asp
Get that Taunton book. We picked up a 12" Northfield jointer w/ a 5hp 3Phase motor for cheap. For more than 10 years we've been running it off of 220 with 10hp 3ph and a washing machine slave motor converter we rigged up from an article in the book(sorry I don't even have it any more, so I can't give you more info on the article). Total cost was $65. Used 3ph motors are dirt cheap, nobody knows what to do with them. Don't worry, we can fix that later!
