All ,
Two days ago I was cross cutting a piece of 6/4 Oak that was about 5″ wide on the RAS . When I was about half way through the saw acted like it struck metal and I saw what looked like a spark and then all the lights went off in the shop .As the blade was slowing down much noise was coming from the now wobbling blade . I thought my saw died in action .
What actually happened was a Crow got into a substation in my area and shorted out close to 4,000 people . What happened was when the power went off since the blade was under a load in the middle of a cut the nut on the blade loosened and the blade was wobbling about , I thought the guts had gone south but I inspected the blade and nut and arbor , put it back on and an hour later when the power came back on all is well .
That was a first in 30 years for me , quite an eye opener
accidents only happen when you least expect them
regards dusty
Dusty,
Things to keep in the back of your mind.
Greg
dusty
You are fortunate that your tools survived to work another day ...and so did you. JL
nevermore.........nevermore......
Dusty dealt with this due to a power outage...some people are distracted installing their blades on the arbour, and then have to deal with a similar situation, because the face plates, blades and the retaining nut were installed crooked, and therefore loose. JL
JL ,
Luck , in my case maybe ,timing , who knows . It felt like the arbor shaft had sheared off and the blade and arbor nut were float / wobbling freely .
freak thing to happen for sure
dusty
Dusty
Luck, timing, the writing on the wall...whatever it is, I am glad you are here to beat this around after the fact. JL
Dear Old,
You know, what comes to mind is whether or not i would of had the presence of mind to turn the machine "off" so that it didn't light up when the power came back on. I guess a magnetic switch would prevent it, but a lot of RAS's have mechanical switches. glad all was well................. except for the crow.............
John
J ,
The first thing I did after a quick inventory was un plug the cord from the wall . I had already flipped the switch off .
You are better than me!John
