I have some serious issues with this planer! I get chatter marks at various intervals on the board. Some boards turn out perfect. I have tinkered with the setup numerous times to fix this. The machine was setup perfect from the factory. I checked it with feeler guages and all was dead on. If I joint a board first it seems to help the issue. I feel that the problem is with the chipbreaker. It is very lightweight and the downward pressure comes from 2 metal bands only. I have been woodworking since 1988 and have never seen this before. Has anyone else had this problem. I will be selling this planer and buying another model unless I can fix it. Take a look at the picture.
*Machine has the Byrd head*
Wayne
Wow, that is a beauty of a planer. I live in Colorado and would be willing to take it off your hands :0)
First, never assume the tool was set up perfectly from the factory - it almost never is. Always check everything.
Second, read this article: http://www.taunton.com/finewoodworking/ToolGuide/ToolGuidePDF.aspx?id=2176
Third, throw out the feeler gauges, they only get you close. A good quality dial indicator is an inexpensive investment that will pay dividends. Your manual should list the approximate settings for the following adjustments.
Fourth, can you explain what you mean by "...If I joint a board first it seems to help the issue...."? You should S2S your material before planing it.
Thanks for the advice Tbagn(cool name!). I went through the machines last night for probably the 4th time. I think I have found the fix! I basically set the infeed/outfeed rollers about .03 below the factory recommendation. This was the magic cure. I always felt there just wasn't enough feed pressure.
As far as the jointing issue the problem is less severe on a jointed board but I run a lot of 10"+ lumber that is 14' long that I can't joint. Anyway, thanks for taking the time!Wayne
