Is there a formula for determining the bevel angle on the edges of
the four trapezoids of the lamp shade for a prairie lamp? I know the
length of the trapezoid base and its height. Thanks for your help
tom
I think you're asking: given a regular trapezoid with known height(H) base(B) and top(T) meaurements, find the bottom corner angles. I'm doing the trig as I go along, but I think it would be:
angle = inverse tangent of H/(B-T)
For a lampshade it would be pretty easy to lay out and measure also.
Pete
Pete,
I'm not looking for corner angles, but the bevel angles that will run
along the sides of the 4 trapezoids that will allow them to come
together to make 4 sided pyramid
tom
This online calculator should work.
http://www.josephfusco.org/Calculators/Advanced_Box_Cutter.html
QCInspector,
Thanks so much this is what I needed! What a powerful calculator.
tom
Beware of engineering pocket books! I have spent some interesting time trying to apply a formula to a trapezium because of an error in the definitions of plane figures in my Newnes Engineer's Book,1960 edition.
