My wife is antiqueing a cabinet with water based paints but would like a more durable finish. Would pre-cat lacquer be a viable solution? Thanks, Art
Test it on some scrap. In general, lacquer based finishes contain solvents that will interact with waterborne finishes.
That will almost certaintly be a problem. Contact your local profesional finishing supplier (Sherman Williams Comercial Coatings is one of the best) and ask them what primer/sealer would allow that. In general if the top coat is catalysed then the sealer also has to be catalysed. I have had success applying Shellac then a vinyl sealer then PreCat over that. the Shellac protected the paint work from the sealer.
Pardon my spelling,
Thanks Mike, I'll try he shellac. Arr
