I’ve already gotten some great advice on finishing for this project, but I forgot to ask; What’s a good sanding schedule for red oak, both solid and rotary cut plywood? Right now it’s straight off the table saw, a little hairy but the shape is good. I’ve got hand planes, orbital and belt sanders and good old sanding blocks at my disposal, and could borrow a surface planer (power) or jointer if that was needed for some of the boards (4/4 red oak for a faceframe on cabinets) . Any ideas? Thanks
Gotta be careful with the ply, unless it's ProCore. Be sure and check for voids by scraping along the ply with your fingernails, and listening for a hollow sound. The veneers may be really thin. Start with 150, and finish with 220 on the ply. Same with the solid. You can go finer if you plan to fill the grain, but with the coarse grain of Oak, you're wasting your time.
Thanks Tom,
And what if I do find voids? carcasse is built, so I can't change parts. Is there a good way to inject an epoxy to fill the substrate?
I've never found a satisfactory method for filling voids. I usually look at the ply before I build the piece, and cut around them.
Plywood is basically sanded to 180 grit at the factory. Do not sand it with anything coarser and be very careful if you use a ROS. It will quickly cut through the thin veneer. I only sand by hand using 180 grit on a sanding pad.
Edited 11/26/2005 11:22 pm ET by HowardAcheson
I don't think I'd touch veneer plywood with anything less than 220. You would be surprised how thin those veneers are.Regards, Scooter"I may be drunk, but you're crazy, and I'll be sober tomorrow." WC Fields, "Its a Gift" 1934
