I just got a quote of $91.50 for 3/4″ 4 x 8 plain sawn red oak, that was a real shock.
That's what I paid for a sheet of cherry a year ago.
Woody
That seems really high. Last time I bought 3/4 4x8 Red Oak I paid around $50.00. It was good quality also. Of course if I have to buy Cherry, Mahogany, or any hardwood other than Red Oak I have to pay three times as much as the others on this web site.
Sounds like you got a price for a special order from a lumber yard. You may want to look around for some other sources. You need to find a supplier to the cabinet trade, some hardwood suppliers also carry cabinet grade plywood. The last plain sliced I bought was under $60. I found some pretty nice rotary cut, 3/4" red oak, Canadian ply at HD yesterday $42.
Napie,
Did you really need plywood for some reason?
a sheet of plywood is 32sq ft. if you buy rough sawn red oak at say $1.45 a bd.ft. it will cost you $46.40 sure you'll need to plane it and then glue it together if you need the full size but that's no more than about an hours worth of work for me..
I would like to find some rough sawn red oak for $1.45 a brf. I usually pay a little over $3.00 a brf. If he can't get 3/4 sheet of ply for less than$90.00 then I doubt he can get rough red oak for $1.45.
The cheapest r/s Red Oak I've found this year is $2.10 bd/ft and that's if I buy 1000 bd/ft minimum.Normally it's $3.45 bd/ft here (Michigan)
Was this A/A (good both sides)? Makes a big difference if the ply has two "finish" faces.
Seattle, WA prices I paid 08/07/06
White Oak 3/4 Rift/QS $145.00 (Good both sides)
Baltic Birch 3/4 $37.50
Birch 3/4 C-3 $38.00
Birch 1/4 A-3 $19.25
Birch 1/2 shop $30.00
Maple 1/4 A-4 $30.00
Hard Maple 4/4 H&M (10 foot boards 6-10" width) $4.75/bf
Hond Mahog 8/4 H&M $8.15/bf
The plywood prices are about half what I was quoted a year ago--except for the WO ply--I think the quote was $175. All the 3/4" sheet goods are around 11 to 13 ply.
Edited 10/3/2006 6:30 am ET by BobMc
Maybe it is here in Michigan that the price is so out of line. The quote was from a plywood distributer that also sells in small quantities. I used to buy from them all the time and prices were very good and the quality is way above the box stores.
Red Oak 3/4 x 4 x 8 today at Home Depot in Warrenton, VA is $39.99Here: http://homedepot.bighammersoftware.com/SearchTable.aspx?cid=834246&res=3&search=plywoodJohn
That's not plain sawn, that's rotary sawn and it's usually junk at my HD.
Right, I missed the 'plain sawn' part.John
If 'sliced' is the same as 'plain sawn' its $83.20 here:http://www.viennahardwood.com/products.htmlJohn
It said $74.07, not that it's much different. I can't believe what has happened to the price of ply. From a Google search the reasons listed are a $50 million purchase by the feds for the rebuiling in Iraq, great...
In Michigan, a couple of places to try...
Menards sometimes has a wonderful selection of hardwoods and plywood at reasonable cost for small qualities. Their clear Aspen Pine is real furniture grade stuff not the construction lumber at the other stores
Johnson's (Charlotte & Grand Rapids) has the board when no else has it (ie 18 ft long QS Sitka Spruce, Bobinga, you name it) but bring your credit card.
http://www.theworkbench.com/home.php
Public Lumber (Det) has better prices but is hit or miss. It is a good source for boat building supplies like Teak & Holly plywood, mahogany, & straight grained White Oak for steaming, etc. Last year got a couple of long pieces of Purpleheart that only cost me a few bucks because they were ¾ X ¾.
http://www.publiclumber.com/
Try Toledo Plywood, in Toledo, Ohio. They have a website, just google their name.
Jim Diedrich
last week I paid 73$ apiece for several sheets of 3/4 birch ply!
it was 53 and change just last year, same dealer...
This is becoming a problem. Tough to pass on to a customer.
There are quite a few grades of face veneer available on plywoods ranging from rotary cut to plain sliced veneer and from workaday logs to plain sliced birds eye maple and better. Many of these are found in commercial specialty sales for professional interior millwork. "Straight grained", "vertical grain", or "plain sliced" are terms that indicate slicing of veneer and reassembly into larger sheets that resemble big glue ups. Most hardwood veneered plywood has face veneers that are rotary sliced like fir plywood. It is a long continuous sheet taken tangentially from the log. There are even variations in plain sliced veneers given the care taken in the assembly and the quality of the wood.
Perhaps you've been quoted a price on a sheet with high quality face veneer(s) and the high price is justified.
I still think that the best veneers are cut, not sliced.
