I have a source for some free maple, most of which is 3″ X 3″ and various lengths. i want to build myself a nice workbench, but i’m not certain that about the moisture content. i don’t want to buy an expensive moisture meter. does anyone have any ideas on how to make a primitive moisture meter or any other ideas on how to tell if this wood is dry enough to glue up? thanks in advance
andrew
A hundred bucks is expensive? I think the homemade one might cost more by the time you verify the settings. The free wood offsets the cost of the meter already.
*If you're serious about this as a profession, as you seem to say, invest in one. I'd buy one before spending the money on a dovetail jig. :) You need one. Get one. Period. Scott
You could always cut a small sample and weigh it then cook out all the moisture using a microwave then re-weigh.
I'm going to try that. since all i need to know is whether the wood is dry enough to start working without problems your idea should work perfect.
FWW issue No. 53 July/August 1985 has a article on building a moister meter.
Scott
http://www.woodweb.com/KnowledgeBase/KBPPAirDryingLumber.html
Try this site for more information.
