I recently purchased downloadable plans for a workbench from FWW. When I printed it out the text was very faint and incomplete. My printer has new ink. Any thoughts on a fix for this? Thank you.
If you can read the pdf file on the computer screen, you should be able to print it. Does the printer do OK with other documents?
Problem solved. Unchecked grayscale box.
Which workbench plan is it?
